Do you have Crystal Reports installed on the same system?
If so, it is a known issue that you must rename or remove 'UFLCAPW.DLL' in the C:\WINDOWS\CRYSTAL directory. You may also need to do the same with 'UFLDT??.DLL' (date file) if you are still experiencing trouble.
If not, try re-installing QCW.
