Hi John,
There are no field checks available for Quik Reports nor EDI Bridgeworks, so you will have to turn off the flat / keyed field checking for these start list entries in the Configure DataCare menu.
The DataCare table for OE needs to be updated for the 6.5A version; for the meantime, also turn off the field checking for OE6.5A. A new release of DataCare should be coming soon with the new field checking table.
In all cases, the Phase 1 and 2 checking is unaffected and will work just fine.
For the issue with SA, is this Softrak's SA? If so, do you use it in conjuction with Quik Invoice for Windows? If this is the case, let us know. The only other report of this issue involved QIW items and the SR update.
