#35055 - 01/17/13 02:51 PM Go green - destination options
JohnK Offline
Good day everyone,
Most reports have an output process which defaults to “Printer” which means the user has to select something else everytime.
Is there a place to set this so that the default destination is something other than "Printer"...
Thank you and,
Cheers, JK
#35056 - 01/17/13 02:58 PM Re: Go green - destination options [Re: JohnK]
Use Adagio ePrint and turn on "Paperless" under User Preferences and the output will be automatically named and filed in a Folder as a PDF.
#35057 - 01/17/13 03:11 PM Re: Go green - destination options [Re: Retired_Guy]
JohnK Offline
Thank you for the recommendation however my question stands.
We are not looking for a work around - the user wants to change the default from printer to file.
Is their a way?
Thank you and,
Cheers, JK
#35058 - 01/17/13 03:14 PM Re: Go green - destination options [Re: JohnK]
No, the default is always printer.
#35059 - 01/17/13 03:25 PM Re: Go green - destination options [Re: Softrak Support]
Michael Mulrooney Offline
And, I suspect, which would then default to your "Windows Default Printer" which could be something green.
#35060 - 01/17/13 03:41 PM Re: Go green - destination options [Re: Michael Mulrooney]
JohnK Offline
Roger wilco...
A path forward ...
Thank you!
#35061 - 01/17/13 03:50 PM Re: Go green - destination options [Re: JohnK]
I believe the "user" will soon get tired of entering a "file name" for the green output.
#35068 - 01/18/13 04:44 AM Re: Go green - destination options [Re: Michael Mulrooney]
JohnK Offline
Good point - I am pretty sure the PDF engine we use provides a default file name so, hopefully the users will just be able to hit "Ok, Ok, Ok" kind of thing.
Does the built in Adagio PDF writer allow for a preview right after the file is created w/o keyboard input?
Thank you!
#35071 - 01/18/13 05:49 AM Re: Go green - destination options [Re: JohnK]
Adagio ePrint is a "solution" NOT a "work around".
#35077 - 01/18/13 08:33 AM Re: Go green - destination options [Re: Michael Mulrooney]
When using Adagio ePrint to generate PDF outputs of reports, there are options to allow immediately opening the PDF to view without any mouse-clicks, or opening the folder in Windows Explorer where the PDF was saved. These options can be set on a report-by-report and user-by-user basis.
0 registered (), 112 Guests and 1 Spider online.
14578 Topics
