#62723 - 01/04/20 04:12 PM
Financial Reporter Chart of Accounts
Stranger
I cannot see the 'Chart of Accounts' under View in Financial Reporter. I reset the view, I have looked everywhere to see if it is a floating pop out window, and all other views (account data, department, etc.) are all working fine. I can see them, reset them, and even have them as floating pop out windows. I have expanded the Window across two monitors to see if it is hiding, but resetting the view should fix this anyway.
Additionally, when I go to File/Send to Sheets/Chart of Accounts, Financial Reporter closes. All other selections under this command (account data, department, etc.) generate worksheets just as expected, only the Chart of Accounts causes the crash.
I have reinstalled Ledger, installed the latest Hot Fix, run data integrity checks, tested multiple datasets, done all Windows updates, run anti-virus, other Windows maintenance - nothing I have done solves this issue. No other Adagio or Windows issues that I am aware of.
Any suggestions would be greatly appreciated! Thanks!
Paul
#62737 - 01/07/20 09:43 AM
Re: Financial Reporter Chart of Accounts
[Re: Brian Stief]
Stranger
Hi Brian,
Thank you so much for taking the time to offer solutions to this problem. I appreciate your assistance.
I have tried all the resets and multiple datasets with this problem. I also tried reinstalling, but to no avail.
I set-up a new Windows user account and used the existing Adagio install, and this problem has gone away. I kind of wondered if there was a conflict between Adagio and user account control or a local Windows setting, and this 'solution' can't be a coincidence. My IT and programming knowledge is superficial, but since this does not appear to be a widespread user issue, it is likely a local problem. Maybe it's a filename problem, maybe it's another program I have installed, maybe it's gremlins.
Again, thank you, Brian, for taking the time to assist.
Paul
1 registered (Bruce Gardner),
587
Guests and
Spiders online. |
14578 Topics
