#64896 - 10/06/20 10:37 AM Re: Workstation Install Hangs [Re: Dan_Desautels]
JWH Offline
John Hancock, CPA
Loc: London, ON
Well to keep up to date on this the latest. Still will not work.
For Dan yes the Crystal Runtime did in fact install (V25). So no issue there.
This time I tried a bit of a different approach. I accessed one of the other modules (Ledger). In doing it triggered of course the workstation install. The firsts message I received was "Adagio Common Workstation Setup" message and prompted me to proceed which I obviously did.
It then got to a certain point on the common workstation setup install and this time hung on this box:
"Skipping System Support Files
I:\Softrak\Setup_Redistributable.exe"
It loaded to 77%(FWIW) and then just hung.
My assumption is this hang up and the previous one mentioned in previous posts are related.
This latest attempt again no anti virus was running since I had previously un installed it.
Thanks again in advance if anyone has any information.
John Hancock
John W. Hancock & Assoc. Ltd.
#64897 - 10/06/20 10:49 AM Re: Workstation Install Hangs [Re: JWH]
VickieZaam Offline
Stranger
Loc: Ontario
John, I've had luck at some sites giving me a hard time similar to what you describe by Uninstalling all Adagio programs including Crystal v25 and Softland pdf drivers using a deep uninstall program like Revo (not the Windows uninstall). Then reinstall from scratch with the AV off.
#64899 - 10/06/20 02:31 PM Re: Workstation Install Hangs [Re: VickieZaam]
JWH Offline
John Hancock, CPA
Loc: London, ON
Thanks Vickie I appreciated your input. You're going to make me work on this aren't you? (haha).
I will do that if I have to but as Leigh at Support has suggested it may be a rights issue.
Anyway will do battle again tomorrow.
Thanks again for your input.
John Hancock
#64908 - 10/07/20 06:39 PM Re: Workstation Install Hangs [Re: JWH]
Brian Stief Offline
Waterloo Guy
This is a rights issue.
Are the user accounts settings on the floor?
Brian
Brian Stief,CPA,CA
800.540.3164
#64912 - 10/08/20 12:51 PM Re: Workstation Install Hangs [Re: Brian Stief]
JWH Offline
John Hancock, CPA
Loc: London, ON
Brian what do you mean "on the floor"?
With that said their IT guy (and I use the term loosely trying to be polite) has indicated to me that he did log in as the administrator and had the same issue. He did this without my involvement so quite frankly I don't quite believe him.
Appreciate your input.
John Hancock
#64913 - 10/08/20 02:10 PM Re: Workstation Install Hangs [Re: JWH]
JWH Offline
John Hancock, CPA
Loc: London, ON
Now that I have a bit of time yes to your question "on the floor" i.e. Never Notify is the setting on that workstation.
FYI.
John Hancock
#64915 - 10/08/20 03:29 PM Re: Workstation Install Hangs [Re: JWH]
Brian is referring to the User Account Control (UAC).
By the floor he is referring to setting this to "Never Notify" which requires that you drag the slider bar to the bottom of the vertical scale (aka the floor).
0 registered (), 159 Guests and 1 Spider online.
14578 Topics
