#16302 - 03/12/09 06:59 PM
Re: Incomplete Posting - Help!
[Re: BrendaToo]
Hi Brenda,
What is supposed to happen in this situation is that if a DIC finds no errors, then all function access becomes available. There is a 'flag' set that posting failed and an integrity check is forced. Perhaps try closing and re-opening Ledger, and run the DIC again should you get the same 'only DIC is available' message.
There is a section in the GLWININI.xxx data file called '[Force DIC]', which will have a value for 'Force now' equal to 1 if Ledger is expecting you to do a DIC and will give the message that you indicated. If you edit this file (with notepad), what do you see? I am not recommending you to change anything, just indicate what you see. If you see 1, then the same message will appear. It has to be 0 in order to get your access back, and DIC should be setting this. If you manually change this to get going, you risk further damage.
Do you recall if you had any other functions open in Ledger when you posted the batch which failed? Any other functions open in other Adagio programs?
Regards, Softrak Tech Support
0 registered (),
112
Guests and
0
Spiders online. |
