#16449 - 03/25/09 01:16 PM Financial Reporter AL8.0
Kay Offline
Loc: Fowler, CA, USA
(64.192.6.194)
Is there a way to copy just a single report sheet(s)- not the whole report from one report file to another that already contains report sheets.
I have similar companies (account numbers) in different folders/companies and would like to be able to copy a sheet from one file to another so that the report does not have to be redeveloped. I know that I can copy all of the individual cells and paste into a new sheet BUT the formating is not copied so I have to reformat the entire worksheet.
Kay N. Paboojian, Jr.
#16451 - 03/25/09 01:57 PM Re: Financial Reporter AL8.0 [Re: Kay]
Hi Kay,
Yes, this is possible. Open a Financial Statement for which you want to bring in new sheets. Then from the File menu, pick Import Workbook. This looks the same as Import Spec (browse for a different finanical statement data file), but when you confirm your choice, you will be presented with the sheet names in this new file. Select any or all of the sheet names and they will be copied/merged into your open financial statement.
If you don't see File / Import Workbook in your version of the Financial Reporter in Ledger, it may be that you have to update your Ledger to get it.
#16459 - 03/25/09 07:30 PM Re: Financial Reporter AL8.0 [Re: Softrak Support]
Kay Offline
(64.192.6.194)
Thanks - never would have guessed to use an Import. It appears to work.
#16470 - 03/26/09 12:28 PM Re: Financial Reporter AL8.0 [Re: Kay]
Hello Kay,
Where would you have expected to find it?
0 registered (), 117 Guests and 0 Spiders online.
