#29089 - 09/28/11 09:11 AM Purchase Order - Item Look Up
chinmook Offline
Edward Chris Chin-Mook
Loc: Jamaica
Guys just realized that the PO Requisition item look up does not give me a search on description, is there a way i can modify same.
Edward C Chin-Mook
876-754-7444
876-754-5513
#29094 - 09/28/11 10:32 AM Re: Purchase Order - Item Look Up [Re: chinmook]
Hi, Edward,
In the item lookup window, right click on the column headings row and select Show/Hide Columns. From the Customise columns window, locate and drage the Description column onto theitem lookup window.
#29098 - 09/28/11 11:29 AM Re: Purchase Order - Item Look Up [Re: Softrak Support]
chinmook Offline
Loc: Jamaica
I did that but, I still can not search on the item description, similar to how I search for a Vendor and inventory items in the other modules.
Thanks for quick response.
Edward C Chin-Mook
876-754-7444
876-754-5513
#29106 - 09/29/11 09:08 AM Re: Purchase Order - Item Look Up [Re: chinmook]
Hi, Edward,
This works the same as in other modules.
Using sample data as an example, in the 'Item number' field, press F6 to invoke the Smart Finder. Make sure the item Description field displays in the window. If it doesn't, use POs Column Editor to add it. As in other modules, select the Description field to be searched on. Perhaps select 'Containing' and use 'Bike' as the value, then Enter.
#29171 - 09/30/11 09:05 PM Re: Purchase Order - Item Look Up [Re: Softrak Support]
chinmook Offline
Loc: Jamaica
Thanks, it now works fine. Trick was where and how to add the description field.
Great help....
Edward C Chin-Mook
876-754-7444
876-754-5513
0 registered (), 303 Guests and 2 Spiders online.
14578 Topics
