#36484 - 04/10/13 11:31 AM New computer but no AdagioPDF
KNoel Offline
Loc: Ottawa ON Canada
(216.191.120.2)
Just got a new computer, yeah!!!
No problems running all my Adagio modules but AdagioPDF is not shown as a printer option. Any ideas?
Running GL 9.0D 111017
Karin
#36485 - 04/10/13 11:40 AM Re: New computer but no AdagioPDF [Re: KNoel]
Hi Karin,
Do you have rights to add new printer drivers to your workstation? The workstation setup installs the AdagioPDF printer driver to your workstation, and you need to have rights, otherwise the process will fail.
Perhaps the main install did not put in the \softrak\system\AdagioPDF\AdagioPDF.exe (which is the setup application for the PDF printer driver). If this failed, it would have been noted in the \softrak\ledger\install.txt installation log.
#36486 - 04/10/13 11:44 AM Re: New computer but no AdagioPDF [Re: Softrak Support]
KNoel Offline
(216.191.120.2)
Software was installed by our IT team so would assume they have the rights but will check with them. If the proper rights are there, can it be installed simply by running adagioPDF.exe or do we need to reinstall the modules?
#36487 - 04/10/13 11:45 AM Re: New computer but no AdagioPDF [Re: KNoel]
KNoel Offline
(216.191.120.2)
BTW, other stations, recently installed, do have AdagioPDF...
#36488 - 04/10/13 12:10 PM Re: New computer but no AdagioPDF [Re: KNoel]
The workstation setup must be performed while logged in as you, rather than an IT login. That other stations have this suggest that the workstation setup was not done in the correct way with the correct rights.
#36503 - 04/11/13 11:19 AM Re: New computer but no AdagioPDF [Re: Softrak Support]
KNoel Offline
(216.191.120.2)
We've tried re-installing the workstation modules, under my userid, but AdagioPDF just doesn't want to show itself!
Our IT guru was able to install NovaPDF by running the .EXE from the location mentioned above but when I print to PDF from Adagio it has the "not licensed" blurb at the bottom, so is obviously not functioning properly.
I've attached a copy of our softrak\ledger\install.exe file to see if that might help determine the problem.
Karin
INSTALL.TXT (188 downloads)
#36509 - 04/11/13 03:23 PM Re: New computer but no AdagioPDF [Re: KNoel]
If you tested it using a non Adagio Program, the "not licensed" blurb always shows at the bottom.
#36600 - 04/17/13 11:53 AM Re: New computer but no AdagioPDF [Re: Patricia B.]
KNoel Offline
(216.191.120.2)
Yes, I've noticed that with non-Adagio PDFs but now it's also showing it with Adagio reports too! Any other suggestions on how to get it to not print the "not licensed" blurb?
#36611 - 04/17/13 01:35 PM Re: New computer but no AdagioPDF [Re: KNoel]
Sounds like your IT staff install NovaPDF when you need the AdagioPDF (a licensed OEM version of NovaPDF). AdagioPDF should have been installed when you did the Adagio workstation setup (assuming you did this correctly and you had the appropriate rights for the install to completed.
My suggestion is to uninstall Adagio and NovaPDF from the workstation and then redo the Adagio workstation setup with the correct user permissions (grant the user administrator status).
#37365 - 06/14/13 09:38 AM Re: New computer but no AdagioPDF [Re: Douglas Dickie]
C White Offline
Adagio Fan
Loc: BC, Canada
(209.121.205.192)
I am trying to do the workstation setup for Ledger 9.0D on the 2nd computer in our office (it worked fine on the 1st), and it keeps hanging at the AdagioPDF stage - it isn't even copying the files, it is just gets to the stage of 'skipping file: C:\...\AdagioPDF\AdagioPDF.exe and hangs. Doesn't seem to matter if I run the workstation setup using the ordinary 'open' or 'open as administrator'. Any suggestions?
