Most competent Adagio Consultants should be able to modify the stock Crystal Reports and/or create new ones for you.
A programmer would be required if the Adagio program itself had to be modified in some way and/or a custom utility or macro was required.
I believe that the solution outlined in this tread could be delivered without your having to purchase a copy Adagio Reports, however you would lose the stock report (without the R, L, & D) in the process.
Other custom report may require that Adagio Reports be purchased.
