#45090 - 03/25/15 07:10 AM DataCare Error
Fong Offline
Adagio Ace
Need help to fix:
Item Locations Reorder ... 1 error(s) found .....
DataCare finds this error but no error in IC Integrity check .
#45092 - 03/25/15 07:34 AM Re: DataCare Error [Re: Fong]
Hi Fong,
Versions of Inventory and DataCare? (See Help | About)
#45096 - 03/25/15 08:18 AM Re: DataCare Error [Re: Retired_Guy]
Fong Offline
Adagio Ace
Hi Master!
IC 8.1D(120126)
DataCare 9.0A(110324)
Thanks.
#45129 - 03/27/15 10:33 AM Re: DataCare Error [Re: Fong]
Fong Offline
Adagio Ace
In a different dataset I have IC
Filter Matches ... 93 error(s) found.
Made Rebuild in IC and in DataCare but Filter Match Error keep returning.
#45150 - 03/31/15 08:46 AM Re: DataCare Error [Re: Fong]
Fong Offline
Adagio Ace
Any advice? Please.
#45153 - 03/31/15 09:00 AM Re: DataCare Error [Re: Fong]
Are you running DatCare and the Inventory Data Integrity Check on the same machines?
This is a new one for us, so you may need your Adagio consultant to take a look.
#45154 - 03/31/15 09:26 AM Re: DataCare Error [Re: Retired_Guy]
Hi Fong,
For the versions you are running, DataCare is checking the Item location and Inventory is not. This error is fixed in the current version.
All you need to do is organize your upgrade (and send someone to the AOC!)
#45156 - 03/31/15 09:31 AM Re: DataCare Error [Re: Retired_Guy]
Fong Offline
Adagio Ace
OK thank you Andrew.
But are these errors serious that I need to contact our consultant right away? May be upgrade to 8.1E (2015.02.24) would fix the errors?
What is filter match? is there documentation to look up error messages just to get a little understanding? smile
#45157 - 03/31/15 09:38 AM Re: DataCare Error [Re: Fong]
The Filter Matches identify the items that belong to different Filters you have set up. Not a big issue if the wrong items are displayed, but I wonder why the error keeps returning.
I would be more concerned of the Item Locations error. I would make getting current a priority, but not an emergency.
