#46369 - 07/03/15 10:27 AM
AP Batch not posted to GL
Loc: Ontario
An A/P batch did not get into the G/L. We use AP, BR, and Ledger, and we use a clearing account. Cheques are entered to AP. The entry that goes from A/P to the G/L when retrieved to the G/L is dr expense(s), cr clearing account. The AP batch also goes to the Bank Rec, and then when it goes from Bank Rec to the GL the entry is dr clearing account, credit bank or payables. For this batch we have the retrieved Bank Rec batch, but no batch from AP to the G/L. I therefore have 31 entries sitting as debits in the clearing account. I reviewed the GL batch status report to see if I accidentally deleted a batch, but I didn't. I have a copy of the A/P Posting Journal that shows payments of $300 and cash invoices of $10,565.29. My clearing account is out the total of those two amounts, $10,865.29. The A/P subledger is out $300 from the G/L control account (i.e. the $300 in payments). Any idea how this AP batch could go from AP to BR, and from BR to G/L, but not from AP to GL? If we know what happened we can hopefully prevent a recurrence. Thanks.
#46370 - 07/03/15 10:55 AM
Re: AP Batch not posted to GL
[Re: MER]
Have you checked to make sure that the batch isn't still sitting in Payables waiting to be retrieved into Ledger?
#46375 - 07/03/15 12:32 PM
[Re: Douglas Dickie]
Loc: Ontario
The batch is not still in Payables waiting to be retrieved. Also, it was created in AP so isn't something that would be retrieved into AP. It's retrieved in Bank Rec from AP, and retrieved in Ledger from AP.
#46376 - 07/03/15 01:25 PM
[Re: MER]
If you are running AP 9.2A there is a log that might be useful to try and determine what might have happened.
#46405 - 07/08/15 05:40 AM
Loc: Ontario
Thank you for the additional possibilities, but none of them are the problem (1 data integrity has been checked, 2 no restore at that time, 3 already checked, 4 A/P is reconciled to G/L). Is the following a possibility: A/P batch was posted. If it's retrieved, posted and cleared in Bank Rec Module before being retrieved in the G/L, is it possible that the batch would no longer be available to retrieve in G/L? We were just discussing that something similar happened a few years ago, when we were just starting to use the Bank Rec Module. We posted a batch in A/P, retrieved it in G/L, did not retrieve it right away in Bank Rec but it showed as available to retrieve. It was posted in the G/L, and then it was no longer available to retrieve in Bank Rec. That's our recollection of what happened a few years ago anyway - is that possible?
#46406 - 07/08/15 06:24 AM
[Re: MER]
Loc: Thunder Bay, ON, Canada
When the batch is posted in AP, the data for the GL batch retrieval goes into one file and the data for the BR batch goes into another. When the batch is retrieved in BR, it has no impact on the file for the GL batch retrieval. That file should sit there until the retrieval is done in GL. So if things are functioning properly, it's not possible. 4 A/P is reconciled to G/L). But in your first post you said the AP Control is out from the GL by the $300 that should've been in the AP batch. Therefore a dating issue could still be a possibility. But since we don't have all the information, this is very difficult to troubleshoot in the forum. If you want me to look at it, the easiest way to diagnose this would be for you to send me a backup of your data. I can review the logs and check the database. Regards, Dan Desautels
#46410 - 07/08/15 08:08 AM
[Re: Dan_Desautels]
Loc: Ontario
Thanks Dan. A/P to G/L was 'reconciled' in terms of knowing that the $300 difference was the Payments part of the missing batch. I manually entered the missing batch to the G-L (I was going to just enter the summary from the A/P posting printout, but for 31 entries I entered all the detail so it would show in the G/L), so now it's reconciled with no difference. If it happens again I will give you a call to discuss checking a data backup.
Mari
0 registered (),
303
Guests and
2
Spiders online. |
14578 Topics
