#46520 - 07/15/15 05:03 PM Report Set output to a single PDF?
Is there any way to print a report set with several reports in it to one PDF? The client uses Cute PDF.
The report set consists of a financial statement and the corresponding Detail Listing.
#46521 - 07/16/15 04:22 AM Re: Report Set output to a single PDF? [Re: Steve Schwartz]
Dan_Desautels Online   content
Loc: Thunder Bay, ON, Canada
Cute PDF has a merge files function. But I'm assuming you want to automate it as part of the report set process.
Dan Desautels
DezTek Solutions Inc.
Thunder Bay, ON
#46523 - 07/16/15 05:37 AM Re: Report Set output to a single PDF? [Re: Dan_Desautels]
Yes, you assume correctly. Right now it defeats the purpose of running a Report Set if it pauses after each report to wait for user imput.
#46525 - 07/16/15 05:48 AM Re: Report Set output to a single PDF? [Re: Steve Schwartz]
Warren Karges Offline
ePrint's options permit this configuration to work with a report set. I tested running two statement groups where both the groups had their print options overridden and set to be appended to the same filename, and it created one file with all the report output as desired. Printboss could also do this.
2015-07-16 9-48-33 AM.jpg (130 downloads)
Description: output configuration
Edited by Warren Karges (07/16/15 05:52 AM)
Warren
#46529 - 07/16/15 08:22 AM Re: Report Set output to a single PDF? [Re: Warren Karges]
Warren's right. This is pretty straightforward to do with ePrint.
0 registered (), 112 Guests and 1 Spider online.
14578 Topics
