#49996 - 05/17/16 04:41 PM GridView 9.2A (Repeating Values & Sub-Total)
MarlonMF Offline
Loc: Los Angeles, CA
(69.163.55.12)
On the release notes from GridView 9.2A:
"A new option allows you to have the repeating values in a printed View suppressed on all rows but the first and total row." - Can this be turned off?
On another topic:
Sub-Total:
Is there an option where I can change the subtotal by whatever column I pick which do not depend on how the data is sorted? For instance, the data is sorted by Item and then by Customer Number but I want it to be sub-total by Customer Number?
Marlon
Edited by MarlonMF (05/17/16 04:42 PM)
#50007 - 05/18/16 02:17 PM Re: GridView 9.2A (Repeating Values & Sub-Total) [Re: MarlonMF]
MarlonMF Offline
(69.163.55.12)
Any thoughts?
1. Can the option be turn off?
2. Can the subtotal be base on the column that the user pick instead of base on how it is sorted?
Marlon
#50008 - 05/18/16 02:37 PM Re: GridView 9.2A (Repeating Values & Sub-Total) [Re: MarlonMF]
Hi Marlon,
Sorry for the delay.
1. Don't format the View as a report, and then the duplicates won't be suppressed.
2. In order to calculate a subtotal, the records must be sorted so that all the record needed for the subtotal arrive at the same time. I'm not sure how you would want the information presented. I can imagine a circumstance where the subtotals you wanted were calculated in another View, and then read when needed in the first View the user is looking at.
I would post examples, but GridView 9.2B workspaces are not backwards compatible.
