#53643 - 05/04/17 02:47 PM
Error : Invalid formula name <bMultiCurrency>
Adagio Fan
Loc: Seattle, Washington
(162.246.92.26)
I've been getting this error when I try to print reports in inventory. Particularly the transaction history report. When I get the error it hangs up Agagio and I am forced to close inventory and reopen it.
Invalid formula name.jpg (112 downloads)
Edited by Clint (05/05/17 08:58 AM)
#54377 - 07/18/17 03:12 PM
Re: Error : Invalid formula name <bMultiCurrency>
[Re: Softrak Support]
Adagio Fan
(162.246.92.26)
The version we are using is 9.2A (170608) and continue to get the <bMultiCurrencies> Error in inventory when trying to print transaction reports
We do not use MultiCurrency.
I am told this has been a problem since September or October of last year.
We are getting another dialog box every time order entry is opened. It says that document statistics is incorrect and will be updated. Its more of a nuisance than anything else, but that ones been a problem since early 2015.
I've talked to our consultant several times about both these issues and he has pointed me here. I've just failed to be persistent at getting this resolved.
Thanks!
#54378 - 07/18/17 04:09 PM
[Re: Clint]
Hi Clint,
Using the same version of Adagio Inventory as you, and previewing the Transaction History report on sample data for just shipments (as you did) or other selections, I was not able to replicate a problem.
Are you able to replicate the same error in Adagio Inventory sample data? Just to confirm whether the issue is with the setup or the data.
If single-currency sample data also gives the same error, then these are the correct files that should exist on your system: - \Softrak\Inventory\Inventory.exe dated Jun 5, 2017 - \Softrak\Dict\ files @N92AI.SSI and @N92AR.SSI both dated May 30, 2016 - \Softrak\Inventory\StandardReports\ICtransh.rpt dated Jun 24, 2015
If I edit this RPT file with the Crystal Reports designer program, I see a formula <bMultiCurrency> in the report, though I don't know exactly how it is used. It looks like a true/false variable. And this report is based on a temporary work file, so a successful print of this report presumes that the data passes an integrity check, and this work file gets created successfully.
If you have a \Softrak\Inventory\ModifiedReports directory with the same report file ICtransh.rpt in it, this would mean that someone has saved a modified version of the Transaction History report for you. If the file date is older than that above, it is based on an earlier program version and would require updating with the new reporting environment. I don't suspect this is your scenario, but it must be mentioned.
As for the other Order Entry message you are getting, regarding document statistics being updated, this message would appear if the stored order count is different than the number of records to be displayed in the grid, when Enter Orders is first opened. This message is here for legacy reasons, and should never appear now unless there were problems in the hardware or network environment, not allowing correct values to be saved with the data. My belief is that something is going wrong with your system, either on a particular workstation or the network environment. If so, I wouldn't be able to assist over this support forum, and that would need to be investigated with your Adagio consultant and IT support. Anti-virus software may also be a culprit.
What version of Order Entry are you using? I presume 9.2A, since Inventory is also at that version, but this needs to be confirmed.
Regards, Softrak Tech Support
#54379 - 07/18/17 04:23 PM
[Re: Clint]
Hi Clint:
How are sales orders entered into OE? Are there any methods other than manual keying of orders such as EDI processing?
#54380 - 07/18/17 04:45 PM
Adagio Fan
(162.246.92.26)
Thanks for the quick response!
I can replicate the error in the sample data.
The only file that doesn't match is the: \Softrak\Inventory\StandardReports\ICtransh.rpt dated Jun 24, 2015 It is date Dec 5, 2015
I do not have the \Softrak\Inventory\ModifiedReports directory
As for Order Entry we are using 9.2A 160707
And Bruce, the only way we enter sales orders manually.
Clint
Edited by Clint (07/18/17 04:47 PM)
#54382 - 07/18/17 05:05 PM
[Re: Clint]
Hi Clint,
Since your report date is newer than what it should be, this means to me that either someone has modified this report, or some previous installation mis-dated this report, and a later upgrade or service pack was not able to overwrite this file with one that had an earlier date. In either case, this would appear to be the culprit.
If you have a \Softrak\Inventory\Backup folder and in one of the sub-folders, this ICtransh.rpt with the correct June 24, 2015 date, you can try replacing the wrongly-dated report with the good one. If you don't have this report file in a backup folder, then you should contact your Adagio consultant and they could do this replacement for you. --- If you don't have any external process for adding/deleting orders, such as EDI or automated import, then my first suspicion is bad hardware/network. Easy for me to say, to be fair.
#54394 - 07/19/17 01:12 PM
Adagio Fan
(162.246.92.26)
I've reached out to our consultant for help with the report, and hopefully that resolved the error.
I'm thinking that the miss-match could come from when I deleted some obviously corrupt data using GridviewRW at the suggestion of our adagio consultant. I feel if it were a hardware or network issue it would be hard to miss over last 2 or so years this has been happening. Is there any course of action you can recommend in diagnosing the problem.
Thanks, Clint
#54397 - 07/19/17 02:21 PM
[Re: Steve Schwartz]
Adagio Fan
(162.246.92.26)
I'm fairly certain I deleted data in GridviewRW around April of 2014. I'm being told by my users that this Order Entry popup has been a problem since 2015. It seems hard to believe that it would take a year for the error to rear its head.
0 registered (),
112
Guests and
0
Spiders online. |
